SaintGrimm
Feb 01, 2017Aspirant
R6300V2 Bridge Mode Prevents Port Forwarding! Help!
I have spent over a total of 100 hours trying to get port forwarding to work on my network so that I can use the remote access feature on the Plex Media Server app. I've done all the basics, rese...
- Feb 01, 2017
That's it!
Your internet port has a 100.x.x.x address. canyouseeme.org shows a 76.x.x.x.
That says that either your ISP's modem is doing its own NAT routing or that your ISP is using carrier NAT. On paper at least 100.x.x.x is reserved for carrier NAT.
See if you can find the manufacturer/model for that modem. You also might need to contact your ISP, and see if they have some way to keep that port open.
Another thought is that you could try changing the port number (say to 49152) in the R1 forwarding rule and also in the plex server configuration. It's possible that using a port in the "private use" range will work better.
SaintGrimm
I'm not fully sure what you're wanting me to look at, is this right? I tried to block out anything that might be bad to show this time :P lol
Feb 01, 2017Guru - Experienced User
That's it!
- SaintGrimmFeb 01, 2017Aspirant
It's after hours today, but I'll call our ISP tomorrow. I really don't know where another modem could even be. When we have issues and they have to come fix it, they just screw around with the box that's on the outside of the house, it's not a modem/router or anything and goes from the side of the house down into the ground.
The plex "out" port HAS to be 32400 according to their website. I've tried putting the in port as different things and leaving the out as 32400 (as described as a possible option on their website) but that didn't change anything either.
Thank you for all of your help! Hopefully my ISP can take it from here. And if they can't or if what they want me to do ends up being just as much of a headache as getting this far, I think I'll just buy a raspberry pie and wire it directly to R1 at once it seems to work when connected to R1.
- StephenBFeb 02, 2017Guru - Experienced User
SaintGrimm wrote:
I really don't know where another modem could even be.It sounds like carrier NAT then. The IPv4 addressing system (x.x.x.x) was limited to a max of 4 billion addresses (and the overall framework didn't allow all of the addresses to be used). As the internet grew, we ran out of addresses. IPv6 is the long-term solution, but rollout has been very sluggish. Carrier-NAT is a stop-gap solution - and just like home NAT it does create some connectivity issues.
If the ISP is using carrier NAT the port might fail to open (or drop) from time to time, no matter which router you connect it to.
But if R1 turns out to be reliable, you might want to invest in running an ethernet cable from the bedroom to the office. That will get you better performance anyway (locally at least).
Anyway, let us know how it works out.
