whelanta
Dec 17, 2019Aspirant
R6300v2 connect to ZTE MF920T troubleshooting
Issue: unable to connect ZTE MF920T 4G LTE wifi router to R6300v2 via WPS buttons Actions taken thus far: - Reset R6300v2 to Factory Defaults - disabled all security (i.e. now OPEN) on R6300v2 - ...
- Dec 17, 2019
What makes you think that you can connect 2 routers together via wps? WPS is designed to connect a router and a wireless device like phone/tablet/computer. Not another router.
Running 2 routers isn't ever recommended as you'll run into nat issues.
https://kb.netgear.com/30186/What-is-Double-NAT
One needs to be the primary router and the other in AP mode or bridge mode.
If you search for connecting a hotspot to a router, you'll find many answers on how to do it. None of which use wps.
whelanta
Dec 18, 2019Aspirant
Thank you. I now have a much better understanding of WPS.
After reseting the R6300 to factory default, establishing a bridge was easy with the Netgear instructions...as long as one is patient.,,really patient!
Of note is that after a bridge is established, the Netgear router being used as a bridge disappears from the list of possible WiFi's (although it does appear as a device connected to the primary router).
Again, thanks for the help.
TAW
Dec 18, 2019Guru - Experienced User
in bridge mode, the router doesn't retransmit the wifi.
If you're able to hardwire the R6300v2 to the ZTE you can put it in AP mode and it'll act as its own access point.
But in bridge mode, thats exactly what it is. A wireless bridge between the zte and the r6300 so you can use the ethernet ports.
