tdmchris
Sep 29, 2017Aspirant
R6300v2 connecting smart tv magnavox
I'm trying to connect my TV to wireless. It says to put pin number in the router settings. I can't figure out where to put the pin number when I go to settings.
- Sep 30, 2017
Which TV model?
Connecting a "smart" TV is usually down to working your way through the configuration screens.
In general these devices are incredibly dumb.
If you have a TV with a LAN port, I would seriously consider that option, perhaps with Powerline Ethernet. Much less flaky than wifi.
michaelkenward
Sep 30, 2017Guru - Experienced User
Which TV model?
- tdmchrisSep 30, 2017Aspirant
Thanks..finally figured it out..
- michaelkenwardSep 30, 2017Guru - Experienced User
tdmchris wrote:Thanks..finally figured it out..
Well done. What was the trick for you? It might help someone who turns up with the same challenge.
It took me 1.5 hours and I can't begin to tell you how because I have almost 0 skills. I used Netgear Genie ..configured the internet and then the wireless. However, every time I go back to TV..the connections are lost and I have to do something again..I think it's the TV.
