tdmchris
Sep 29, 2017Aspirant
R6300v2 connecting smart tv magnavox
I'm trying to connect my TV to wireless. It says to put pin number in the router settings. I can't figure out where to put the pin number when I go to settings.
- Sep 30, 2017
Which TV model?
Connecting a "smart" TV is usually down to working your way through the configuration screens.
In general these devices are incredibly dumb.
If you have a TV with a LAN port, I would seriously consider that option, perhaps with Powerline Ethernet. Much less flaky than wifi.
michaelkenward
Sep 30, 2017Guru - Experienced User
tdmchris wrote:Thanks..finally figured it out..
Well done. What was the trick for you? It might help someone who turns up with the same challenge.
tdmchris
Sep 30, 2017Aspirant
It took me 1.5 hours and I can't begin to tell you how because I have almost 0 skills. I used Netgear Genie ..configured the internet and then the wireless. However, every time I go back to TV..the connections are lost and I have to do something again..I think it's the TV.
- michaelkenwardSep 30, 2017Guru - Experienced User
Once the wifi is set up you should be able to make the connection in the TV's settings.
Do it there and they should stick.
