Frame
Sep 09, 2021Aspirant
R6300v2 error message
After I updated firmware to version V1.0.4.52_10.0.93 on my R6300v2 I'm getting the following message after typing in new URL: "Hmm. We’re having trouble finding that site. We can’t connect to the...
Sep 09, 2021Guru - Experienced User
Anytime there's issues after a firmwware update, the first step I usually recommend is a factory reset and reinstall.
Have you tried this?
- FrameSep 09, 2021Aspirant
If I do a factory reset will I lose all settings? Is there the way how save them?
- plemansSep 09, 2021Guru - Experienced User
You can take a backup of the settings but if its an old setting causing the issue, restoring it is just going to restore the problem.
What you can do, try making a backup configuration.
Then reset and restore the backup.
If you still have the issue, the reset and manually reinstall it without using the backup.
