kimming
Dec 04, 2017Aspirant
R6300v2 Firmware - cannot log into routerlogin.net
I'm trying to install the firmware upgrade but cannot get logged into http://www.routerlogin.net. I've tried multiple times/days and different browsers. Any suggestions? I really want to get the...
- Dec 04, 2017
Got it to work - I was connected by ethernet - but not directly off the router. Once I did that, it all worked just fine.
kimming
No need to be snarky. Here's the error message when I try to connect at routerlogin.net:
Unable to connect
Firefox can’t establish a connection to the server at routerlogin.net.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
