killroyfu's avatar
killroyfu
R6300v2 firmware discrepancy 1.0.4.34_10.0.92
I am seeing a new firmware version of 1.0.4.34_10.0.92 through the firmware upgrade assistant on my router. I am seeing http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2-V1.0.4.32_10.0.91.zi...
  • killroyfu's avatar
    Dec 06, 2018
    I found the answer to the discepancy. The support pages link to the firmware update support article is wrong. The link is labled with the correct version number but the link takes you to the download page for a previous version. If I go to the downloads page directly instead of the support page, I get the correct link to the firmware download page.
