zu5be
Aug 28, 2016Tutor
R6300v2 Firmware is invalid
Hello there. I am on firmware version V1.0.3.26_10.0.70 on model R6300v2 and wanted to update to the most recent version. While trying to update manually, that is by downloading the firmware an...
- Aug 29, 2016
Tried all sorts of stuff.
Finally, I used the DD-Wrt firmware to upgrade.
First brushed the stock firmware with DD-Wrt(initial release for the router) and then upgraded to stock (latest Update) from DD-Wrt.
Worked for me!
if somebody else wants to follow this method, do it at your own risk.
Cheers and thanks, everybody.
Retired_Member
Aug 29, 2016YOU have to EXTRACT or unzip it first!
zu5be
Aug 29, 2016Tutor
Thanks for your reply. Yes, I did! :manlol:
