zu5be
Aug 28, 2016Tutor
R6300v2 Firmware is invalid
Hello there. I am on firmware version V1.0.3.26_10.0.70 on model R6300v2 and wanted to update to the most recent version. While trying to update manually, that is by downloading the firmware an...
- Aug 29, 2016
Tried all sorts of stuff.
Finally, I used the DD-Wrt firmware to upgrade.
First brushed the stock firmware with DD-Wrt(initial release for the router) and then upgraded to stock (latest Update) from DD-Wrt.
Worked for me!
if somebody else wants to follow this method, do it at your own risk.
Cheers and thanks, everybody.
zu5be
Aug 29, 2016Tutor
Worked for me!
- Retired_MemberAug 30, 2016
Before this had that router use anything other than Netgear FW? I'm asking because I have two them and thinking about trying 3rd party FW
- michaelkenwardAug 30, 2016Guru - Experienced User
@searay wrote:... thinking about trying 3rd party FW
Any reason for this? Beyond the challenge.
Yes, I have 2 of them sitting around. I resently switched my r7000 to Xwrt-Vortex while it's not perfect it does offer some unique controls and options. One thing certain it will be a cold day in he// before ARLO is an option.
- zu5beAug 30, 2016Tutor
Yes, when I purchased it in china, I asked the seller to brush it with Asus- Merlin firmware. I used it for a year and often had an issue with a sudden drop of internet speed which didn't make sense as I was on a 100Mbps connection. Rebooting the router fixed the problem.
I used a special image to brush back to stock and was not able to update the firmware to a newer version. Then I brushed it again with DD-Wrt from there tried to go back to stock with updated firmware and failed. i researched a bit and found that there are two versions of R6300v2 CH and without CH, I brushed it with CH VERSION FIRMWARE. it worked but only to find out that it has no updates since the initial release. So, back to DD-Wrt again and tried brushing the updated firmware version of R6300v2 and it worked!
