19th
Aug 19, 2022Follower
R6300v2 firmware not available
Email notification from NETGEAR says that new firmware is available. Firmware upgrade assistant in advanced router update version check says no new firmware version available. How can I update if email is correct??
1 Reply
What actual firmware version are you on?
Those emails tend to be mass emails sent out regardless of what firmware version the user is on so its good to compare what version you're on versus the release version.
https://www.netgear.com/support/product/r6300v2.aspx
