bertc
Jul 09, 2020Guide
R6300v2 firmware not updating from V1.0.3.6_1.0.63CH
Hello - I am running firmware version V1.0.3.6_1.0.63CH Wanted to be sure I was current for any vulnerabilities, so . . . Download R6300v2-V1.0.4.36_10.0.93.chk from netgear.com Went into the Ad...
- Aug 02, 2020
I post the following for those who stumble upon this thread in the future and wonder what the eventual solution was.
By cobbling together the steps below from various sites, threads, suggestions and then modifying it for current conditions.
This worked for me and left me right where I wanted to be .
I used the following procedure specifically to remove the CH (charter) version and revert back to V1.0.3.22_10.0.67 – same version, but no longer Charter. From this I could then upgrade to the latest version from Netgear. If you’re looking to do something different you will need to modify these instructions for your purposes. Again, this worked for me, but may not for you for any number of reasons. Good luck.
1. Manually Backup your router settings - write them down
2. Flash the new firmware dd-wrt.K3_R6300V2CH.chk (can now be found here https://forum.dd-wrt.com/phpBB2/download.php?id=42538&sid=417bea094969968cd6a3c07c50635a51)
3. This will change the firmware to V1.0.3.22_10.0.67, which is no longer Charter
4. NOTE: The router interface will change drastically. See here for more details on dd-wrt: http://en.wikipedia.org/wiki/DD-WRT
5. You will need to navigate to flash the new updated firmware; On the Administration tab there is a FirmWare Upgrde tab
6. Flash the new firmware with the latest version from Netgear – currently R6300v2-V1.0.4.36_10.0.93
6. Wait till the router is fully flashed and restarted.
7. Factory reset your router.
bertc
Jul 09, 2020Guide
My apologies for not being able to follow simple directions, discussion, and links.
Are these the steps you are refering to?
Shady. I will link you to the firmware I used... http://flyhalf205.com/dd-wrt.K3_R6300V2CH.chk
Get rid of your router's CH Version?
1. Backup your router settings
3. NOTE: The router interface will change drastically. See here for more details on dd-wrt: http://en.wikipedia.org/wiki/DD-WRT
4. You will need to navigate to flash the new updated firmware.
5. Flash the new firmware which currently is V1.0.3.22_10.0.67
bertc
Jul 17, 2020Guide
Hello - any chance someone could review the last post/question and advise? Thank you!
