Alysonia
Jul 08, 2020Aspirant
R6300v2 firmware not updating
My R6300v2 router is not updating at all. It is showing Firmware Version V1.0.3.6_1.0.63CH. I have already downloaded the newest update on my PC, however when i try to browse for the file and open it...
antinode
Jul 08, 2020Guru
> Model: R6300v2|AC1750 Dual Band Gigabit router
Connected to what?
> [...] I have already downloaded the newest update [...]
Which was?
> [...] it keeps giving me an error. [...]
Was there a message associated with this "an error"? Use your words.
> [...] My download speed is over 220 and my upload peed is only at 0.5.
"220" _what_? "0.5" _what_?
> [...] I called my provider and they said I needed to update my router.
That might be true, but some actual evidence might be nice. If you
haven't changed the router firmware, and it worked properly at some time
in the past, then why assume that the same firmware is now the cause of
your (new) problem?
Have you tried connecting a computer directly to your modem (assuming
that you have a modem)?
> [...] I feel like I have tried everything.
You're wrong. For example, did you try a Web search for, say,
"V1.0.3.6_1.0.63CH"?
Alysonia
As for the error message it literally says Firmware is incorrect. I am trying to update from V1.0.3.6_1.0.63CH to Firmware Version 1.0.4.36. I have downloaded the file for that firmware version and it still wont update.
