Alysonia
Jul 08, 2020Aspirant
R6300v2 firmware not updating
My R6300v2 router is not updating at all. It is showing Firmware Version V1.0.3.6_1.0.63CH. I have already downloaded the newest update on my PC, however when i try to browse for the file and open it...
bertc
Aug 02, 2020Guide
Alysonia,
It took me a while to get up the nerve to attempt the below procedure as any failure could easily result in a bricked/unusable router. But since it was successful I thought I would share with you in case you're still looking and willing to take that risk.
I used the following procedure specifically to remove the CH (charter) version and revert back to V1.0.3.22_10.0.67 – same version, but no longer Charter. From this I could then upgrade to the latest version from Netgear. If you’re looking to do something different you will need to modify these instructions for your purposes. Again, this worked for me, but may not for you for any number of reasons. Good luck.
1. Manually Backup your router settings - write them down
2. Flash the new firmware dd-wrt.K3_R6300V2CH.chk (can now be found here https://forum.dd-wrt.com/phpBB2/download.php?id=42538&sid=417bea094969968cd6a3c07c50635a51)
3. This will change the firmware to V1.0.3.22_10.0.67, which is no longer Charter
4. NOTE: The router interface will change drastically. See here for more details on dd-wrt: http://en.wikipedia.org/wiki/DD-WRT
5. You will need to navigate to flash the new updated firmware; On the Administration tab there is a FirmWare Upgrde tab
6. Flash the new firmware with the latest version from Netgear – currently R6300v2-V1.0.4.36_10.0.93
6. Wait till the router is fully flashed and restarted.
7. Factory reset your router.
- yassefDec 23, 2020Aspirant
This was exactly what I was looking for. Followed the instructions and was able to update the firmware to the latest version 1.0.4.50
Thanks
