StephieM
Mar 07, 2017Follower
R6300v2 Firmware updating
I use an R6300v2 provided by Charter. With the recent vulnerability issues, I want to make sure the firmware is up to date. The Support Site says the latest is 1.0.4.06. The router reports current is...
- Apr 19, 2017
Your only option is to either stay with the current CHarter firmware, or flash the router to DR-WRT and then flash it to the most recent firmware of the "normal" 6300v3 router.
michaelkenward
Mar 08, 2017Guru - Experienced User
StephieM wrote:I use an R6300v2 provided by Charter.
That is probably the answer. If Charter provided it, then it may be a custom version. You will probably have to ask them for new firmware.
