callwill
Sep 05, 2021Aspirant
R6300v2 firmware V1.0.4.46_10.0.93 No 2.4Ghz network
R6300v2- new to me but used, was having work from issues for wife and kid so took out the WNDR 3700 we had since 2009. Things seemed to be great at first. I set the 2.4 and 5Ghz netorks to both hav...
Sep 05, 2021Guru - Experienced User
You can manually update it.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
R6300v2 | WiFi Router | NETGEAR Support
Try manually updating. Then do a factory reset and reinstall.
- callwillOct 04, 2021Aspirant
Finally had the time, upgraded the firmware to version V1.0.4.52_10.0.93
I thought i has seen there was something newer.
I gave the 2.4 and 5 different ssids and passwords and i can now see both networks.
If i do a "reset" will it send the firmware back or will it stay what i updated too?
