rstuve147
Jul 16, 2022Follower
R6300V2 firmware v1.0.4.46_10.0.93
Running Desktop windows 7 64bit with Router R6300v2 at firmware level v1.0.4.46_10.0.93. Running FW check from router it says no updates available. When looking online in NETGEAR web site it says the...
michaelkenward
Jul 17, 2022Guru - Experienced User
rstuve147 wrote:
Why does the check from the router say no updates available?
Because it is wrong?
Those "through the device" checks are not reliable, especially if you are using a mobile app to run the check.
