Rigante
Jul 13, 2017Aspirant
R6300v2 Firmware Version V1.0.3.22_10.1.13SW Firmware update Question
Hardware Version R6300v2 Firmware Version V1.0.3.22_10.1.13SW GUI Language Version V1.0.3.22_2.1.33.8 When I go to http://www.netgear.com/support/product/R6300v2.aspx#Fir...
michaelkenward
Jul 14, 2017Guru - Experienced User
Rigante wrote:
I download the update manually and try to Upload it, only to get " THIS IS THE INCCORRECT FIRMARE!" or something to that effect... Am I missing something here?
Hard to say. You did unzip the firmware?
Which version did you retrieve. V1.0.3.22_10.1.13SW is pretty old. Did you try something between that and the most recent?
A clearer description of "or something to that effect" might help.
