DashQuark
Apr 13, 2017Aspirant
R6300v2 in AP Mode
This configuration was working except for wireless range, so I added an R6300v2. "AP" mode
R6300 LAN ------ Switch ------- TiVo
TiVo ...
- Apr 22, 2017
Thanks for the reply. They can not communicate in the third configuration. It is too bad that netgear does not document what AP mode does. I was able to get everything working by only using the lan ports and undoing the AP mode and just disabling DHCP. I set a fixed IP address below the first address given by the main router and now I can't figure out how to manage the 2 routers I am using as APs. But, since it works that is a problem for a different day.
DexterJB
Apr 18, 2017NETGEAR Moderator
Hi DashQuark,
All three setups should work. On the third setup, may I know how you're testing the TiVo's whether they can communicate?
Dexter
Community Team
DashQuark
Apr 22, 2017Aspirant
