Wolfangovich
Mar 20, 2016Aspirant
R6300v2 Port Forwarding no working on Port 19132
I have built a server, and trying to build a Minecraft server for my son. It is setup properly, windows firewall has the approriate rules in place. I set the port forwarding on the router and cannot ...
- Mar 20, 2016
Did you verify that the server is up and running by connecting from a local PC?
yes I RDP into the server, start the software, watch it start up and run.
I am unable to connect to the minecraft sever on the LAN or externally. According to all instructions I have it configured properly, just not sure why I cannot connect.
thanks anyways for the help.
TheEther
Mar 20, 2016Guru
Does the R6300v2 have a public or private IP address on its Internet/WAN port? If it's private, then you have another router, likely your ISP's. You would either need to set up port forwarding rules on that router, or convert that router into a bridge.
