Wolfangovich
Mar 20, 2016Aspirant
R6300v2 Port Forwarding no working on Port 19132
I have built a server, and trying to build a Minecraft server for my son. It is setup properly, windows firewall has the approriate rules in place. I set the port forwarding on the router and cannot ...
- Mar 20, 2016
Did you verify that the server is up and running by connecting from a local PC?
yes I RDP into the server, start the software, watch it start up and run.
I am unable to connect to the minecraft sever on the LAN or externally. According to all instructions I have it configured properly, just not sure why I cannot connect.
thanks anyways for the help.
Wolfangovich
Ok,
the machine that the minecraft server software resides on, I have checked a doubled checked the IP address.
NAT is set to OPEN
I have rebooted the router. PF still there.
Now I do have UPnP on because of other applications. I will disable to see if that is the problem, but I hope not.
will Let you know.
Wolfangovich
Ok,
tried dis-abling UPnP, rebooted router, still nothing.
Re-installed minecraft PE Server, still not able to connect nor when I go to canyouseeme.org it states the port is closed.
Let me know what else I can try. I am stumped.
- TheEtherMar 20, 2016Guru
Intead of using canyouseeme.org, have you tried connecting from a remote PC?
If the answer to both questions is, "Yes," then I don't have any other ideas.
- WolfangovichMar 20, 2016Aspirant
If you cannot connect to the server from your LAN, then your server is not running properly and this is not a port forwarding issue. You need to fix your server before port forwarding will work.
Does netstat -rn on the server show it listening to port 19132?
