hansana_A
Aug 28, 2021Aspirant
R6300V2 Readyshare printer
Hi, I'm having an issue with Readyshare printer utility which is, the printer doesn't show up in the Netgear USB Control Centre. I'm using a Windows 10 PC, properties are as follows, Edition Windo...
- Sep 01, 2021
Hi michaelkenward NamelessPerson ,
It requires Internet Connection to properly work with "NETGEAR USB Control Centre", I have used a repeater and connected it to my NETGEAR and it worked well and still do!
hansana_A
Sep 01, 2021Aspirant
michaelkenward
Sep 01, 2021Guru - Experienced User
Thanks for the update. But I am now lost.
Does this mean that you have fixed your problem?
- hansana_ASep 01, 2021Aspirant
YUPâđđ michaelkenward
