NetGeek420
Dec 25, 2020Follower
R6300v2: restore software/firmware using Android
A friend installed dd-wrt and vpn on spectrum router and didn't finish adjusting settings. It has no security and is using one single channel rather than scanning
Dec 26, 2020Guru - Experienced User
So what are you asking help with?
Removing ddwrt?
If so, you'll want to look on the ddwrt forum for help in removing its firmware. the wrong process can brick a device and they're going to know better how to remove their own firmware than we will.
