Mitchdojo
May 11, 2017Follower
R6300V2 slow internet over wire
So after performing many tests, I have come to the conclusion that our router favors wifi over LAN connection. I have run a speed test on my phone over wifi and I get a whopping 21mb down while on my...
- May 17, 2017
Hi Mitchdojo,
1. What is the firmware version of the router?
2. Please try using another Ethernet cable.
3. Please try using another port on the router.
4. Please check the LAN port status under Advanced > Advanced Home > Internet port box > Show statistics.
5. Does the issue persist on your other wired devices?
6. You can try changing the duplex of the LAN adapter of the computer.
Dexter
Community Team
DexterJB
May 17, 2017NETGEAR Moderator
Hi Mitchdojo,
Dexter
Community Team
