Brian783
May 23, 2017Aspirant
R6300v2 slow wifi speeds
My r6300v2 is getting slow wifi speeds. I have tried changing the channels and still no luck. I am using charter spectrum. Internet from isp modem is 67. When I connect over wifi I get 30. Is the any...
DexterJB
May 24, 2017NETGEAR Moderator
Hi Brian783,
1. What is the firmware version on the router?
2. Does the issue persist on both bands (2.4GHz and 5GHz)?
3. Does the issue persist on all your wireless devices?
4. What is the speed that you're getting when wired to the router?
Dexter
Community Team
- Brian783May 25, 2017Aspirant
firmware v1.0.4.8_10.0.77
issue persist on 2.4ghz. i dont use the 5ghz except for xbox360. nothing else i have will connect to it. so i never tested the 5 ghz.
issue does persist on all devices.
wired directly to the netgear router i got 65.95.
wireless i got 33
on channel 1 for 2.4 ghz
thank you
i connected my phone to 5ghz. i got 3mbs download speed.
