Bigddb86's avatar
Bigddb86
Follower
Dec 19, 2017
R6300v2 slow wifi speeds
  • Hi Bigddb86,
    1. What is the firmware version of the router?
    2. Are all of your wireless devices affected?
    3. Does the issue persist on both bands (2.4GHz and 5GHz)?
    4. Have you tried changing the wireless channel?
    5. Have you tried resetting the router?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Bigddb86,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Bigddb86,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
