kappa436
Oct 26, 2016Aspirant
R6300v2 Unable to log in
- Nov 01, 2016
Dexter, after I did a mental ecaluation and decided that I had made no changes of any kind (including the password) since I installed the router, I did a factory reset - but I got the same error message as before. I then logged in from another connected computer with routerlogin.net with the same results. So i tried 192.168.1.1 and BINGO, got in. I did a version update and now everything is back to where it was and I can see what is connected.
Thanks for the help
DexterJB
Oct 31, 2016NETGEAR Moderator
Hi kappa436,
Thank you for responding. Please keep us posted on the results if resetting is an option.
Dexter
Community Team
kappa436
Nov 01, 2016Aspirant
Thanks for the help
