mamisongo
Feb 15, 2020Aspirant
R6300V2 wifi connection to my wireless headphones problem
Whe I use my Roku app to use my wireless JBLFlex headphones in the 5G home network the conection even do is on my beddroom a few feets awy from my router the conection some times comes and go , The...
- Feb 16, 2020
Hi my friend
Good news the diconecting the router did the job is working fine. Thank you again.
Manny
Feb 15, 2020Guru - Experienced User
From what I could find of the JBL flex headphones, they aren't 2.4gh/5ghz headphones. They're bluetooth. which means they'd connect to your phone or bluetooth watch. Not the router.
Unless this is a different pair?
- mamisongoFeb 15, 2020Aspirant
Thank you for your help
My mistake my headphones conect to the roku app and wifi to the 5g router, the software version on my router isV1.0.3.6_1.0.63CH. I was cheking on google and it shows a diferent version and the netgear site tells me is up to date. In my search in google a sugestion of keeping my galaxy s9 the closest to the route helps even do in my room am a couple of feets away. I have been dealing with these issue for a long time and is getting on my nerves.
Thank you again for your help
Manny
- plemansFeb 15, 2020Guru - Experienced User
mamisongo wrote:Thank you for your help
Manny
roku app on your phone or roku app on a roku?
If you disconnect the wireless headphones, does the phone skip/buffer?
The roku app on my phone, nothing to do with the buffer, not sure what you mean with skiping the buffer.
