mamisongo
Feb 15, 2020Aspirant
R6300V2 wifi connection to my wireless headphones problem
Whe I use my Roku app to use my wireless JBLFlex headphones in the 5G home network the conection even do is on my beddroom a few feets awy from my router the conection some times comes and go , The...
- Feb 16, 2020
Hi my friend
Good news the diconecting the router did the job is working fine. Thank you again.
Manny
Feb 15, 2020Guru - Experienced User
From what I could find of the JBL flex headphones, they aren't 2.4gh/5ghz headphones. They're bluetooth. which means they'd connect to your phone or bluetooth watch. Not the router.
Unless this is a different pair?
mamisongo
Thank you for your help
My mistake my headphones conect to the roku app and wifi to the 5g router, the software version on my router isV1.0.3.6_1.0.63CH. I was cheking on google and it shows a diferent version and the netgear site tells me is up to date. In my search in google a sugestion of keeping my galaxy s9 the closest to the route helps even do in my room am a couple of feets away. I have been dealing with these issue for a long time and is getting on my nerves.
Thank you again for your help
Manny
- plemansFeb 15, 2020Guru - Experienced User
mamisongo wrote:Thank you for your help
Manny
roku app on your phone or roku app on a roku?
If you disconnect the wireless headphones, does the phone skip/buffer?
- mamisongoFeb 15, 2020Aspirant
The roku app on my phone, nothing to do with the buffer, not sure what you mean with skiping the buffer.
What I'm getting at is that when you're listening on your headphones its skipping.
If you disconnect the headphones from your phone and just play directly from the phone, does it skip/disconnect?
