rockmaster
Oct 21, 2020Aspirant
R6330 scheduling greyed out
I set my new R6330 to AP mode, and the Schedule settings are greyed out. (I didn't look to see if the feature is available when AP mode is off). edit: I turned off AP mode, managed to set the time,...
- Oct 21, 2020
I solved my problem. I see that there are scheduling options on the
Advanceed> Advanced Setup >Advanced Wireless Settings page.
rockmaster
I changed the timezone (effectively changing the time to be in the period when the blocking is scheduled), and the wifi is still active, so it seems that the blocking feature is not working with AP mode on. This seems like a bug. Can you fix it, Netgear?
- rockmasterOct 21, 2020Aspirant
Advanceed> Advanced Setup >Advanced Wireless Settings page.- michaelkenwardOct 22, 2020Guru - Experienced User
For future reference:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Thankfully, wifi scheduling isn't in there.
