prcutler13
Feb 11, 2023Follower
R6350 - How long does it last? Ours 5-10 yrs old. Not sure it's getting updates. How do I know?
I want to update my pc. All info I find is about updating through app on phone.
Feb 12, 2023Guru - Experienced User
What firmware is on it?
I don't see the R6350 on the end of life list but all the other routers from that period are on the list so I'd imagine it is EOL.
https://www.netgear.com/about/eos/
But that doesn't mean its garbage time. You just have to realize it doesn't get security updates and probably isn't the greatest performing device anymore since its a couple generations behind performance. But again, if you don't have the fastest speeds anyway and is still doing its job, then not much need to upgrade.
