sweeney42002
Jul 06, 2018Follower
R6350 -ac1750 smart WiFi connection problems
I just purchased R6350 and having trouble getting wifi/and wired connection thru router working properly. I can connect a laptop computer directly to internet from provider and get 30mbps download/5m...
- Jul 10, 2018
Hi sweeney42002,
Welcome to the community!
Please make sure that a factory reset is done after the firmware update and reconfigure the router. Please keep us posted if the issue persists.
Dexter
Community Team
DexterJB
Jul 10, 2018NETGEAR Moderator
Hi sweeney42002,
Dexter
Community Team
DexterJB
Jul 18, 2018NETGEAR Moderator
Hi sweeney42002,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
