Jleake1989
May 25, 2018Aspirant
R6350 -ac1750 smart WiFi
Does it support vdsl?
- May 25, 2018
> R6350 [...]
It's a router, not a modem+router. It neither knows nor cares about
ADSL, VDSL, or any other DSL. (Or cable-TV, or fiber, or ...)
There is some fine print, however. If your DSL service uses PPPoA,
then a combined modem+router may be required. PPPoE should be ok,
however. What did you intend to use as a modem? Who's the ISP?
antinode
May 25, 2018Guru
> R6350 [...]
- Jleake1989May 26, 2018AspirantThat’s what I figured out. I thought it was a router/modem. So I will be going with a different model.
Thanks for the help
