Jleake1989's avatar
Jleake1989
R6350 -ac1750 smart WiFi
Does it support vdsl?
  • antinode's avatar
    May 25, 2018
    > R6350 [...]
       It's a router, not a modem+router.  It neither knows nor cares about
    ADSL, VDSL, or any other DSL.  (Or cable-TV, or fiber, or ...)
       There is some fine print, however.  If your DSL service uses PPPoA,
    then a combined modem+router may be required.  PPPoE should be ok,
    however.  What did you intend to use as a modem?  Who's the ISP?
