Jleake1989
May 26, 2018Aspirant
R6350 -ac1750 smart WiFi
Does it support vdsl?
- May 26, 2018
> R6350 [...]
It's a router, not a modem+router. It neither knows nor cares about
ADSL, VDSL, or any other DSL. (Or cable-TV, or fiber, or ...)
There is some fine print, however. If your DSL service uses PPPoA,
then a combined modem+router may be required. PPPoE should be ok,
however. What did you intend to use as a modem? Who's the ISP?
JJ111166
Jun 21, 2018Aspirant
what do i need to do get my netgear modem to see my router?
michaelkenward
Jun 21, 2018Guru - Experienced User
Start by telling us what the modem is and if you really do own an R6350 or have just joined in on a conversation started by someone with that hardware.
If you do have an R6350, a good place to start is with the Quick Start guide. Find it here:
>>>R6350 | Product | Support | NETGEAR<<<
Go through it and tell us where things go wrong, or bits you don't understand.
By the way, as you have joined in on an older discussion there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
Just click the Create a New Discussion button at the top of this section's front page:
R6000 Series AC WiFi Routers - NETGEAR Communities
