RKobe
Jan 16, 2021Aspirant
R6350 AC1750 can’t connect to internet
I recently bought the R6350/AC1750 router at first I was able to connect to get it working just fine. Then the next day it would not connect to the internet. I would reset the modem and router like I ...
Jan 17, 2021Guru - Experienced User
What modem do you have?
What firmware is on the router?
RKobe
Jan 17, 2021Aspirant
The modem is from COX cable and I have reset the router back to factory setting just like it was straight out of the box.
- plemansJan 17, 2021Guru - Experienced User
which modem is it from cox?
- RKobeJan 17, 2021AspirantI’m not sure. I’m not at my father in law’s house to see. I know it stands straight up. And has the telephone also. They said COX just replaced it about 6 months ago
so its your father in law doing all this?
You're not actually doing it?
