RKobe
Jan 16, 2021Aspirant
R6350 AC1750 can’t connect to internet
I recently bought the R6350/AC1750 router at first I was able to connect to get it working just fine. Then the next day it would not connect to the internet. I would reset the modem and router like I ...
RKobe
Jan 17, 2021Aspirant
The modem is from COX cable and I have reset the router back to factory setting just like it was straight out of the box.
Jan 17, 2021Guru - Experienced User
which modem is it from cox?
- RKobeJan 17, 2021AspirantI’m not sure. I’m not at my father in law’s house to see. I know it stands straight up. And has the telephone also. They said COX just replaced it about 6 months ago
- plemansJan 17, 2021Guru - Experienced User
so its your father in law doing all this?
You're not actually doing it?
- RKobeJan 18, 2021AspirantI’m doing it for him. He is technologically challenged. However, I found out there was a power surge that fried the modem and router. So I’m getting him a new modem with WiFi. He had an antique type power strip or brick of sorts. Thank you for trying to help.
