Jonathan2299
Mar 21, 2023Follower
R6350 AC1750 Slow Wifi Speeds
I setup my R6350 router earlier today and I quickly noticed that the wifi speeds are greatly lower than the router that I was previously using. A laptop that was getting close to 100mbps with the old...
michaelkenward
Mar 22, 2023Guru - Experienced User
Jonathan2299 wrote:
I setup my R6350 router earlier today and I quickly noticed that the wifi speeds are greatly lower than the router that I was previously using. A laptop that was getting close to 100mbps with the older router(which was an AC1900 ASUS) was now getting about 30mbps.
You don't say what the model number is – AC1900 is a speed tag rather than a model number – but the Asus claims a better WiFi spec than the Netgear's AC1750.
The R6350 also dates from 2018, so not that new.
Then there are the questions from Kitsap and plemans, especially the modem between the R6350 and the Internet. Did you reset that before introducing it to the new router?
