ghostaroo
Feb 10, 2025Aspirant
R6350 home page says no internet but it is connected
I've been having a strange almost non-issue with my router, my internet connection is fine, IPV6 tests show it's all good, but the router's home page says there is no internet. Logs show it's connect...
Feb 11, 2025Guru - Experienced User
what modem/gateway are you connected to?
A double nat is the most common reason for that issue.
- ghostarooFeb 11, 2025Aspirant
I'm using a CM1000v2 as a modem. I do have an old R6300v2 set in access point mode to obtain IPs from the R6350 but I'd assume NAT is disabled on it in that mode, disconnecting it has made no difference to the issue.
- plemansFeb 12, 2025Guru - Experienced User
I've never seen that specific issue with one directly connected to a modem and with everything working fine. Interesting. And it even shows up with the 2nd router disconnected.
and you've tried most of the troubleshooting steps I'd use.
Is it causing any issues?
and what firmware is currently installed?
