Rodrimag
Aug 17, 2022Aspirant
R6350 How many devices can I connect
Hi, I have an R6350 and would like to know how many devices (wifi) I can connect. I have approximately 30 devices connected at 2.4GHz and 8 connected at 5GHz. When I try to connect a new one, ...
Aug 17, 2022Guru - Experienced User
Its usually 32 per band. but the R6350 is a pretty basic router. If you can move any of the 2.4ghz devices to 5ghz, you'll do better to even out the load a bit
Rodrimag
So, it means 32 devices at 2.4Ghz and 32 devices at 5Ghz!!! So if I connect a second wifi router (this r6350 connect a second wifi router by ethernet cable), I can double the devices?
- plemansAug 17, 2022Guru - Experienced User
If you've separated out the bands and made sure they're not on the same channel.
but again, its not a flagship router, its a pretty base model one.
While it should support up to 32 devices, if they're higher bandwidth devices, you're going to have issues.
https://kb.netgear.com/24043/How-many-WiFi-client-devices-can-my-NETGEAR-router-support
- RodrimagAug 18, 2022Aspirant
Ok, If I understood you, my router is a basic one, and my devices are simple IoT, like a smart switch, or smart lamp, these devices do not require higher bandwidth. So my idea is to connect a second router to increase the number of devices in my network. In my mind I will have 20 devices on my first router and more 20 devices on the second, my thoughts are correct, adding a router increases the device's number even that I sacrifice a little my bandwidth with a low investment.
- plemansAug 18, 2022Guru - Experienced User
It should work. But put the 2nd router in AP mode.
