Babbitslinger's avatar
Jun 30, 2019
R6350 LAN disconnects repeatedly requiring reset
R6350 brand new running V1.1.0.52_1.0.1 disconnects LAN ports repeatedly. Sometimes one port, sometimes all. Sometimes reset restores. Devices ethernet connected WinXP PC, Directv, and roku puck. H...
  • Babbitslinger's avatar
    Babbitslinger
    Jul 08, 2019
    It looks like the solution rests with adjusting the network adapter to work well with the new router. This is what I did and the ethernet /LAN connection has been stable. WinXP Computer services-device manager-network adaoter-nvidia nforce controller-advanced-speed/duplex setting.
    Then select option to FORCE 100 half duplex. Restart.
    This worked for me so far.
