Babbitslinger
Jun 30, 2019Tutor
R6350 LAN disconnects repeatedly requiring reset
R6350 brand new running V1.1.0.52_1.0.1 disconnects LAN ports repeatedly. Sometimes one port, sometimes all. Sometimes reset restores. Devices ethernet connected WinXP PC, Directv, and roku puck. H...
- Jul 08, 2019
It looks like the solution rests with adjusting the network adapter to work well with the new router. This is what I did and the ethernet /LAN connection has been stable. WinXP Computer services-device manager-network adaoter-nvidia nforce controller-advanced-speed/duplex setting.
Then select option to FORCE 100 half duplex. Restart.
This worked for me so far.
Babbitslinger
Jul 02, 2019Tutor
At this point I may have to admit the fault may be with my HP Pavilion a1600n with an Nvidia eforce network controller. At any rate, as stated before, the wifi is fine. All ports are functioning now.
Babbitslinger
Jul 08, 2019Tutor
