Yuck97
Nov 08, 2022Aspirant
R6350 Netgear Router logon timed out so cant logon through Nighthawk
Can't logon to Nighthawk to reach my R6350 router, message says(logon timed out) have reset, uninstalled, cleared cache, restarted phone, but same message. Router is working fine, but can't logon t...
michaelkenward
Nov 09, 2022Guru - Experienced User
Join the club.
Re: Can't logon to Orbi - "Logon timed out, please... - Page 4 - NETGEAR Communities
and
Re: Nighthawk App Logon Timeout - Page 2 - NETGEAR Communities
The Nighthawk app is bust.
Rumour has it that Netgear is working on it. Sadly, no one from the company seems willing to update users on what is going on.
Yuck97
Nov 16, 2022Aspirant
The problem is with the Nighthawk app and 5G phone. I can logon through a 4G phone. So, Netgear needs to fix the app to work on the newer phones (5G especially).
Thanks for those that replied.
- michaelkenwardNov 16, 2022Guru - Experienced User
Thanks for those that replied.Lucky you. That is not true for most people. It doesn't work on 4G either.
(Can't a 5G phone connect to 4G?)
In reality, the problem isn't so much the mobile connection. The wifi link does not work.
When you connect with the app through wifi, it should offer you the choice of Anywhere Access or Local Wifi. The Wifi bit is bust for many of us.
- bstantonFeb 22, 2023Tutor
Update February 2023. Still not working on my IOS device. Can log on through web browser but I can't believe it's been months and they have patched this issue.
