chuckdavis1964
Jan 19, 2017Aspirant
R6400 – AC1750 Smart WiFi Router—802.11ac Dual Band Gigabit - want to add a second router
My modem is connected to my AC1750 and is broadcasting a wifi signal across my house. When I built my house, I had 12 ethernet ports installed across the house and I want to connect them to a sec...
- Jan 20, 2017
A better choice would a high grade gigabit network switch the type used by larger companies they come up to hugh number of ports and handle gigabit speeds no problem most are rack mount design if your plaining 12 runs for now get 16 to 20 port model for just incase you add another run can not hurt to have few spare.
William10a
Jan 20, 2017Master
- chuckdavis1964Jan 23, 2017Aspirant
Thank you!
Any suggestions as to the best switch?
- William10aJan 23, 2017Master
Cisco and Netgear both make good high end switchies check some manage and some unmanaged manage switchies lets you control the switch via a computer to control its ports. An unmanaged is like what you would find at most places that sales network switchies for home user plug them and connect your network and away you go.
Here is the link to Netgear's unmanaged switchies http://www.netgear.com/business/products/switches/unmanaged/gigabit-unmanaged-switch.aspx there are many to choice from.
