rfo056's avatar
rfo056
R6400 - AC1750 Smart WiFi Router Connected No Internet
Trying to understand how this could happen, can only guess for now. Wifes phone Samsung AO2S connecting to router but with no internet access. Kept trying to find problem on phone, turned out that th...
  • michaelkenward's avatar
    Sep 16, 2021
    rfo056 wrote:
    ....turned out that the connection to router was allowed to connect. But router blocked it from accessing internet.
    How did you work out that the router is the culprit?
    Have you enabled access control on the R6400?
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Block Access to Your Network.
    Is that what you mean by this?
    rfo056 wrote:
    I have access to router blocked by all until I go into advanced security an allow them to connect.
    Not sure that I follow the language there, but if you have told the router to block all new devices then maybe it is just doing what you asked it to do.
    Why would it block your wife's phone when you have given it permission? Because, from what I read here, Apple and others like to change the Mac address of things like mobile phones. So the next time your wife tries to connect to the wifi, your router sees a new device and tells her to go away.
