Kturner's avatar
Kturner
Follower
Jul 13, 2017
R6400 - Custom DNS Settings Change When Parental Controls are On
I changed the DNS settings to be set to google DNS servers. But when I turn the parental controls back on, the DNS settings automatically revert back to the previous settings. How do I prevent this f...
  • DexterJB's avatar
    DexterJB
    Aug 28, 2017
    Hi Pugg,
    The DNS values will change when you enable Parental Controls. Disabling Parental Controls should set those values back to how you had it before. You can also find it in the router UI via Advanced > Setup > Internet Setup > Domain Name Server (DNS) Address.
    Dexter
    Community Team
