InLikeFlint
Oct 23, 2018Aspirant
R6400 - ready share access to HDD by MacBook Air stopped working
I am running an external hard drive (Western Digital vis usb) through the router (dual band gigabit, R6400 Smart WiFi router, firmware version v1.0.1.42). I am using a MacBook Air (2012 - High Sierra...
- Oct 30, 2018
This has been resolved! Not sure why but it is working. I do know what I changed though.
There was a printer plugged into the back USB port. I removed the printer and plugged in the HDD. After a few moments, the white light for the rear USB slot went on and the readyShare drive became visible in Finder on my MAC and all the data is there. For the record I tried moving the drive back to the front USB slot and the light for the front USB port remained off and the drive did not show up on Finder.
Is it possible for a USB slot to go "bad" out of the blue?
Regardless - the router is functioning well enough. Thank you for the service call - it coincided with my getting the router to recognize the HDD but it was still appreciated. The unit is way too old to be covered by a warranty but it is back to doing the job.
Thanks again!
DexterJB
Oct 29, 2018NETGEAR Moderator
Hi InLikeFlint,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
InLikeFlint
Oct 30, 2018Aspirant
Thanks again!
