RDK
Apr 15, 2021Tutor
R6400 - specify DNS for DHCP
I would like to change the DNS information which is supplied to clients via the DHCP function in this router. Right now it uses its own address (ie someting like 192.168.1.1). Is there a way to ov...
antinode
Apr 15, 2021Guru
> [...] Right now it uses its own address [...]
That's required to make those "routerlogin" names work.
> [...] Is there a way to override this [...]
Nothing supported on these consumer-grade routers. Supplying your
own (more configurable) DHCP server might be the most practical scheme.
RDK
Apr 15, 2021Tutor
OK Thanks...
