JeffStent
Sep 10, 2016Tutor
R6400 AC Wifi Router Printing
My Canon D530 will not print by AirPrint through my Netgear R6400 AC router. Printer works via USB through router from the desktop printer just fine. Will not print via wifi from iPad or iPhone. ...
- Sep 11, 2016
I apologize. It seems I misunderstood. I thought that if the printer worked via USB to the router, and was accessed sucessfully from my desktop computer, that I could also print via wifi. Must not be the case.
Thanks, for the clarification.
Jeff
VE6CGX
Sep 11, 2016Master
There are Airprint capable printers. Airprint is done via wireless. Usually the printers are Airprint compatible wireless printer.
Is your user manual says your printer is Aairprint capable? Is it wireless printer first of all? Google Airprint , NFC.
JeffStent
Sep 11, 2016Tutor
Jeff
