paul-s-1056
Nov 17, 2016Aspirant
R6400 AC1750 Can't connect on Wi-Fi
Just got the AC1750 WiFi router: can connect via ethernet fine, but I can't get a WiFi connection to the router on either 2.4 or 5Ghz...I may have to go back to my Belkin WIFi-n model, at least tempo...
- Nov 19, 2016
I fixed the problem myself - I reset the router, then everything came up... I must'a accidentally turned off the WiFi portion of the router when I set it up the first time...
...although all the "normal" lights on the front panel were on, including both the 2.4 and 5Mhz ones...
michaelkenward
Nov 18, 2016Guru - Experienced User
Can you say a bit more about what is going on?
We can't read much from "I can't get a WiFi connection to the router" unless you tell us what you have done and where it fails.
You can find the user manual here:
NETGEAR AC1750 Smart WiFi Router Model R6400 User Manual
Maybe that will help.
Some more general stuff here:
R6400 | Product | Support | NETGEAR
paul-s-1056
Nov 19, 2016Aspirant
- michaelkenwardNov 19, 2016Guru - Experienced User
Stuff happens.
