paul-s-1056
Nov 17, 2016Aspirant
R6400 AC1750 Can't connect on Wi-Fi
Just got the AC1750 WiFi router: can connect via ethernet fine, but I can't get a WiFi connection to the router on either 2.4 or 5Ghz...I may have to go back to my Belkin WIFi-n model, at least tempo...
- Nov 19, 2016
I fixed the problem myself - I reset the router, then everything came up... I must'a accidentally turned off the WiFi portion of the router when I set it up the first time...
...although all the "normal" lights on the front panel were on, including both the 2.4 and 5Mhz ones...
paul-s-1056
Nov 19, 2016Aspirant
michaelkenward
Nov 19, 2016Guru - Experienced User
Stuff happens.
